Bahco Bowsaws
Bahco Bowsaws
- Large moulded grips
- Finger/knuckle protectors
- Easy change blade and tension mechanism
- Supplied with peg tooth (dry cutting) blades
The 533mm(21") bowsaw has a frame, which tapers towards the tip to allow better access between branches. The 610mm(24") is of the standard bowsaw design. Both feature large moulded grips and finger/knuckle protectors, easy change blade and tension mechanism. Both come fitted with peg tooth blades. Two types of replacement blades are available: Peg tooth for cutting dry wood and general applications; or the Raker tooth blades for cutting green or wet timber. Saws and blades made in Sweden.
