Woodworking Wisdom
Before You Start - Carving
Carving Chisels
Principle 1: Work with the grain, not against it
Before you start carving, take a moment to understand the wood in front of you.
Grain direction affects everything:
  • How cleanly the tool cuts
  • How much resistance you feel
  • Whether fibres tear or slice cleanly
Carving against the grain often leads to tearing and sudden slips. Working with it allows tools to move more smoothly and predictably. A simple test is to take a light cut and observe how the surface responds. If it feels resistant or rough, adjust your direction.
One helpful tool: A general-purpose carving knife with a fine edge helps you read the grain more clearly and respond with control.
5 Piece Carving Set
Principle 2: Sharpness changes everything
Carving with a dull tool quickly turns into hard work. Instead of slicing cleanly, the blade drags through the fibres. That means:
  • More force
  • Less control
  • Higher chance of mistakes
Sharp tools don’t just improve results - they make carving feel easier and more rhythmical. If your tool feels like it’s resisting the wood, it’s usually time for a quick touch-up rather than pushing through.
One helpful tool: A leather strop with compound keeps edges sharp between full sharpening, with minimal effort.
Principle 3: Secure the work before you begin
Trying to hold your work while carving limits both safety and control. Movement - even slight - makes it harder to guide cuts accurately and increases the risk of slipping.
Before you start, make sure your piece is properly supported and held in place. This lets you:
  • Focus fully on the cut
  • Use controlled pressure
  • Keep both hands working safely
One helpful tool: A carving vice or bench clamp provides stability, allowing you to carve more confidently.
Veritas Carver's Vice
Curved gouge
Principle 4: Take less than you think you need
One of the most common carving mistakes is removing too much material too quickly. Carving is a gradual process. Shape develops through a series of small, controlled cuts - not one decisive removal.
Working slowly allows you to:
  • Refine form as you go
  • Correct direction easily
  • Build confidence in each cut
It also makes the process feel more considered and less pressured.
One helpful tool: A small gouge or Vee‑tool offers greater control for shaping without removing too much material at once.
Final thoughts...
Carving rarely goes wrong in one obvious moment. More often, small decisions build up over time - in the way the wood is read, the tool is prepared, and the work is approached. Taking a little time before you start wood carving helps remove uncertainty and gives you more control from the first cut. These simple habits don’t add complexity - they create clarity.
Whether you’re carving for the first time or developing your skills further, returning to these foundations will always make the process feel more confident, more controlled, and ultimately more enjoyable.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our blogs?
Get in touch!
Get in touch via our social media platforms. Find us on Facebook or Instagram.
Leave a comment
