Woodworking Wisdom
Christmas Tree | Skew Chisel Techniques | How To
header
Practice your skew chisel and woodturning techniques with this fun and simple Christmas tree decoration project.
In this Woodworking Wisdom demo, Colwin shows you how to make a number of different Christmas tree shapes using different chisel techniques and tools. The aim of which is to develop your skills while all the while making these fun little decorations - great for using up offcuts and to sell online or at Christmas craft fairs.
Watch Colwin in our Woodworking Wisdom demonstration or continue to read out article to make yours.
Skew chisel Christmas tree
Begin by roughing down your blank to a cylinder and turn into a cone shape.
7531
7546
Then, clean and finish with a skew.
7547
Mark the branches with a pencil and make V cuts using the toe of the skew.
7556
7560
Taper cut to the bottom of the V using the heel of the skew and repeat these steps until all branches are made.
7563
7573
Using a parting tool, cut down to give separation between the branches and the base. Leave around 10mm in the centre.
7588
Taper the bucket then cut in some v cuts and use a wire to burn some decorative lines.
7592
7601
Finish by parting off with the skew.
7609
close-up-final
Bead cutter Christmas tree
Here’s an alternative Christmas tree shape using the Easywood bead forming cutters.
Turn a tapered blank and use the bead forming tool to create a beaded finish. Then use the Easywood burning wires to define each bead.
7617
7626
Skew heel cut Christmas Tree
Another variation is the skew heel cut tree.
Begin by turning the blank down to a cone again, but this time held in a chuck.
7637
Mark out the bottom branch. Then using the heel of your skew, push the fibres back from around 6mm back. Repeat this down the entire length of the tree.
7638
7639
7653
Using the toe of the skew, tidy up and shape the base.
Finish by parting off.
7663
7665
final
More simple Christmas decorations
For more Christmas decoration inspiration, explore our Woodworking Wisdom ideas and advice section, which is packed with ideas to suit all abilities. We have selected a few of our favourites below.
Made it, share it!
If you have made any of these Christmas projects we would love to see them. Share your pictures with us on social media. Search and tag @axminstertools on Facebook or Instagram or upload to our online gallery.
Leave a comment
