Woodworking Wisdom
Commercial Veneers - How To Lay Them
Veneer leaves substrate glue and roller
Method
Step 1
Prepare the materials ready for veneering: substrate, veneer leaves, glue and roller.
Step 2
Place thick paper on the baseboard inside the bag. This prevents any glue ‘squeeze out’ from sticking the project to the base.
Thick paper inside the bag on the baseboard
Step 3
Apply and roll the glue onto the substrate, ensuring that there’s an even layer across the whole surface and lay one pair of leaves on top. Turn the project over, apply more glue and lay on the second pair.
Apply the glue
Both leaves laid on the substrate
Step 4
Insert the project into the bag and cover it with more sheets of thick paper.
Project inserted into the bag
Project covered with thick paper
Step 5
Seal the bag and switch on the vacuum pump. This sucks the bag down over the project to apply atmospheric pressure.
Optional
The setting time for the glue in the bag can be significantly shortened if additional heat is applied over the top.
Bag sealed and bag drawn down over the project
Full vacuum pulled
Step 6
Lay an electric blanket on top of the bag, switch to the ‘max’ setting.
Electric blanket on top of the bag
Cover the electric blanket with an old duvet
Step 7
To trap the heat, cover the electric blanket with an old duvet. The glue will take around an hour to fully cure.
Step 8
When the glue has cured, take the project out of the bag and remove the tape on each side using water, a Webrax pad and a scraping implement.
Cleaning off the tape
Step 9
Let each side dry thoroughly and then sand. The completed book matched panel is shown with a coat of finishing oil to enhance the grain pattern.
Leave a comment
