Woodworking Wisdom
Decking Screws
WoodSpur Decking Screws
Decking Screws
What is a decking screw?
Decking screws are screws designed specifically for decking. A wooden deck is an outdoor structure that has to bear shifting loads, day after day, so it is important to use screws that will stand the test of time. What this means is that your deck needs to be able to hold itself together.
To achieve an attractive, solid and sturdy deck that you can enjoy safely, it’s always best to opt for purpose-built decking screws.
WoodSpur Screws
Advantages of decking screws
  • For quick and reliable assembly, some deck screws feature a Torx T25 drive. With this type of drive there’s minimal risk of cam-out and greater transmission of torque. This makes them excellent for pressure treated, tanalised timber.
  • What's more, the sharp, penetrating tip eliminates the need for pilot holes, saving you time and effort!
  • Some decking screws are corrosion resistant to prevent rusting and weakness of the structure over the years.
  • Deck screws are far superior to nails as the are more secure. They also allow boards to be easily lifted to gain access below the deck for maintenance or repair.
Discover more…
Enjoyed reading this article? Pop into our Axminster store to see our range of screws and other fixtures and fittings. We also have several other woodworking projects for you to explore. Try something new with our selection of indoor and outdoor projects. Why not get creative and learn how to make a birdhouse or get top tips on laying a wooden deck?
Get involved!
Have you completed building your own deck at home? Or maybe you lay decking for a job? If so, we’d love to hear from you. Get in touch and tell us your thoughts about our decking screws. Better still, show us your creations! Either comment below, or get in touch via one of our social media platforms. Find us on Facebook, send us a tweet or connect with us on Instagram.
Leave a comment
