Woodworking Wisdom
EcoPoxy in Education | Andrew's Project
As Andrew's project began to unfold, he decided that he wanted to use EcoPoxy within more of his designs. The initial research from the dissertation is intended to influence the end of the year project but Andrew decided to bring its influence forward.
The experimentation started on a small scale, simply to gauge whether his ideas would work as he had hoped. Andrew built a small former using melamine coated board, calculated the internal area and converted it to millilitre volume. Unfortunately, Andrew hit a snag when he forgot to use any releasing agent, meaning the melamine stuck to one side
Mould Clamping
A second attempt was made in a larger former with the hand screw press. Andrew used a wax furniture polish as a release agent. This solved the issue and created a 2mm thick sheet that was partially see-through and resembled alabaster.
EcoPoxy panel
Hand Screw Press
Releasing Agent
Following this, Andrew decided that the best way to pursue this would be to use it as a laminated surface; steam bent to form a constructional veneer. Rounded edges were easily achieved on the router table, aided by the smooth cut of the resin.
moulded EcoPoxy
Wooden Mould
EcoPoxy in mould
Curved panel
Curved Panel
Due to the initial design changing, Andrew decided to create a shaped mould in order to form channels into the surface. These channels act as registration points for smartphones and tablets to be placed, while also adding stability.
Curved mould
Curved mould clamp
The next stage of the make was the laminating of the ash doors, which have a surface laminate of the wool composite. Once the core had been made, a carefully book-matched piece of the same constructional veneer was added for the interior. This was followed by a wool composite surface laminate for the outside. The process was completed immediately after the wool had been pressed, as the flexing was more effective when it’s not fully cured.
Door former carved from Celotex insulation
Melamine board used to make the wool/resin mould.
n order to gauge the consistency of the wool, I used a large piece of perspex pressed onto the surface
The finished result
Finished open
Finished closed
Thank you to Andrew for sharing this project with us, we can't wait to see what else you create!
Want to know more about EcoPoxy? Take a look at our Knowledge Blog to discover more about the natural Epoxy & Resins for Woodworking or browse the EcoPoxy range...
Leave a comment
