Five Ideas For Halloween Decorations
Know which project you want to start?
| Branch Pumpkins | Pumpkin Blocks | Wood Block Ghouls |
| Stacking Pumpkin | Ghosts |
We've prepared a selection of templates for you to use with a scroll saw or as a painting outline. We've used some of them for our projects, but there's plenty more to choose from!
Project 1 - Branch Pumpkins
This project can be made to any scale, we've used a small tree branch to demonstrate its simplicity. This makes it an ideal introduction to woodworking.
What you'll need
Tools & equipment
- Handsaw - we have used this Hardwood Kataba Saw. Alternatively, you can use a bandsaw
- Paint - we have used Polyvine Acrylic Enamel Paint - Orange 20ml
- Paintbrush - choose from our range
- Pencil and Scissors (If using a stencil)
Materials
- Any circular offcut of wood - we have used a tree branch
Project 2 - Pumpkin Blocks
These blocks were made from a discarded edge of timber, so we used a bandsaw as opposed to a handsaw. But if your material is already square then a handsaw will do. Although it's a simple concept it can easily take more complex designs, such as a 3D puzzle with a different design painted on each side or can be carved to shape.
What you'll need
Tools & equipment
- Bandsaw - alternatively, you can use a handsaw
- Planer - can be used if you wish, dependant on desired finish
Materials
- Offcut of wood - we have used a discarded timber plank
- Decorative items - we have used shavings from a hand plane
Project 3 - Wood Block Ghouls
These planks should be readily available in your workshop and the prep can be as simple as just cutting the wood to size. As we've used an old pallet we put ours through a planer, making the surface more accepting of paint.
What you'll need
Tools & equipment
- Saw - we have used a Bosch Circular Saw. Alternatively, you can use a handsaw
Materials
- Offcut of wood - we have used an old pallet
- Decorative items - we have used shavings from a Veritas dowel cutter
Project 4 - Stacking Pumpkin
This is another easy but effective idea that can take more elaborate painted designs. You could even hollow it out to create a candle holder.
What you'll need
Tools & equipment
- Drill
- Glue - we have used Titebond Original Wood Glue 237ml
Materials
- Plank of wood - we have used a split timber
- Decorative items - we have used a twig
Project 5 - Ghosts
These ghosts can be stuck into your front garden to spook trick or treaters. We have used a pyrography pen to draw the face but you could also carve or paint it on. Download our free stencils for more design ideas.
What you'll need
Tools & equipment
- Scrollsaw
- Pyrography Pen - if you wish to finish with some finer details
- Paint - we have used Polyvine Acrylic Enamel Paint - White 20ml
Materials
- Offcuts of wood - we have used ply
- Decorative items - we have used shavings from a dowel cutter
Terrifying Templates
Download and print your free stencils here! Click the button below to download the whole pack, or alternatively click the links below each image to select your favourite.
Download Halloween template pack
The downloads are all sized to A4 - to change the scale just alter the settings on your printer.
These project ideas were found online, credits as follow:
Project 1 - Branch Pumpkin [http://findcraftideas.com/wood-pumpkin-crafts.html]
Project 2 - Pumpkin Blocks [https://festival-collection.com/wooden-halloween-decorations]
Project 3 - Wood Block Ghouls [http://kindofpets.com/wood-halloween-crafts.html]
Project 4 - Stacking Pumpkin [http://www.diyswank.com/rustic-wood-pumpkins]
