Hand Planes | Choosing the Right Plane for the Task
A Guide to Hand Plane Types
Understanding the Types of Hand Planes
Each hand plane is designed with a specific purpose in mind. Here's a breakdown of the most popular types:
- Smoothing Planes Ideal for final surface preparation, leaving timber silky smooth and ready for finishing.
- Jack Planes A versatile all-rounder used for rough dimensioning and general flattening.
- Fore Planes Longer than jack planes, they’re great for flattening large boards and preparing surfaces for finer work.
- Block Planes Compact and easy to handle, perfect for trimming end grain and small adjustments.
- Router Planes Used for cleaning out recesses like dados and grooves with precision.
- Rabbet (or Rebate) Planes Designed to cut rabbets along the edge of a board.
- Shoulder Planes Similar to rabbet planes but with finer control, ideal for trimming tenons and shoulders.
- Bench Planes A category that includes jack, fore, and smoothing planes—your go-to tools for general planing tasks.
- Plough Planes Used to cut grooves and slots, often for drawer bottoms or panel work.
- Model Making & Miniature Planes Small-scale planes for intricate or delicate work.
- Scraper Planes Excellent for dealing with tricky grain or tear-out, leaving a polished finish.
- Specialist Planes Includes compass planes, bullnose planes, and others designed for niche tasks.
The best plane for the job depends on the task at hand. For example:
- Preparing rough stock? Start with a jack or fore plane.
- Finishing a surface? Reach for a smoothing or scraper plane.
- Cutting joinery? A shoulder or rabbet plane will give you clean, accurate results.
Understanding the characteristics of each plane helps you work more efficiently and achieve better results.
Maintenance & Sharpening
A well-maintained plane is a joy to use. Here are a few tips:
- Keep blades sharp Regular honing ensures clean cuts and reduces effort.
- Check the sole A flat sole is essential for accuracy. Flatten it if needed using abrasive paper on a flat surface.
- Lubricate moving parts A light oil prevents rust and keeps adjustments smooth.
Store properly
Keep planes dry and off metal surfaces to avoid corrosion.
Explore maintenance & sharpening
Quick Tips at a Glance
- Smoothing planes are perfect for final surface prep.
- Jack planes are your go-to for general-purpose planing.
- Fore planes excel at flattening large boards.
- Block planes are ideal for trimming end grain.
- Router planes clean out grooves and recesses.
- Rabbet and shoulder planes are essential for joinery.
- Plough planes cut grooves for panels and drawers.
- Scraper planes tame difficult grain with ease.
- Keep blades sharp and soles flat for best results.
- Choose the right plane for the job to save time and effort.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our other blogs?
Get in touch!
If you’ve used a certain type of hand plane for one of your projects, or have bought one of our planes, we'd love to hear from you. Comment below or send us a photograph and tell us all about what you've been up to, or what you've bought. Alternatively, get in touch via our social media platforms. Find us on Facebook or Instagram.
