Woodworking Wisdom
How To Make A Kitchen Towel Holder
Step 1
Prepare the material for the kitchen towel holder to the correct size, make the ends square. Leave the roller material oversize for turning.
Material preparation
Marking the tails
Three dovetails
Step 2
Mark out and cut dovetails on the sides.
Step 3
Mark out the dovetail pins and saw out the waste.
Mark the pins
Cutting the pins
Step 4
Test fit the joints part way.
Fitting the joint
Hole centres
Step 5
Mark out the centres (arrowed) on sides for the roller. Then, drill a 35mm hole to a depth of 10mm.
Step 6
Clamp the sides together, rout out twin roller recesses.
Optional
Use a hand router for the recesses
Routing the recess
Step 7
Chisel the sides (arrowed) of each recess.
Using a large chisel to clean up the recess
Step 8
Mark out, drill and countersink two 4.5mm fixing holes (arrowed).
Making the screw holes
Cleaning inside faces and masking joints
Step 9
Clean up and sand the inside surfaces, and then mask off the joints.
Step 10
Apply two thin coats of Osmo-PolyX finish with a lacquer brush. Allow 6-8 hrs between each coat, and remove the tape when dry.
Osmo-PolyX
Scrap piece insertion
Step 11
Prepare a scrap piece to the exact inside dimension, and glue together. Remove glue ‘squeeze out’ from inside when dry.
Step 12
Plane off the waste on the dovetail joints.
Cleaning up the joints
Step 13
Mark out the radius on each corner, and then disc sand to shape.
Marking and shaping the corners
Exterior finishing
Step 14
Sand the exterior and all sharp edges and apply two coats of Osmo PolyX to the bare surfaces.
Step 15
Turn the roller blank to a cylinder. Use a test piece of ply (35mm hole drilled in it) to check the diameter along the whole length.
Roller
Step 16
Measure the length between the two recesses in the sides, and transfer this to the roller and part off. Apply two coats of Osmo PolyX to the roller.
Sizing the roller
Step 17
Fit the roller to complete the kitchen towel holder.
A simple wall mounted kitchen towel holder like this works very well; this one in oak has been in continual daily use for over thirty years.
Completed project
Alternative holder
Leave a comment
