Woodworking Wisdom
How to Make an Egg Cup and Holder
Egg Cups and Holder how to
A cracking project, this turned egg cup and holder is sure to eggcite any woodturner! This small project is great for using offcuts and for practising simple turning skills.
Watch Colwin in our Woodworking Wisdom demo, or follow our step by step guides below.
Egg cup
Prepare your blank
Mount your blank between centres and rough down to a cylinder before sizing the tenon to fit your chuck. Then, hold in the chuck and rough down to size.
Rough down to a cylinder
Size the tenon to fit your chuck
Hold in the chuck and rough down to size
Hollow the egg cup
Start hollowing out the inside of the cup. Finish the hollowing out, checking the size as you go with an actual egg.
Check the size as you go
Use a depth gauge to check the depth and to mark. Then make a cut with a parting tool to the stem side of your egg cup.
Take the top of the egg cup down to size giving you a 4-5mm wall thickness.
Mark the depth of the stem
Cutting with a parting tool
Aim for a 4-5mm wall thickness
Shape the stem
Remove waste timber from the stem the turn and refine the shape of the cup.
Refine the shape of the cup
Shape and blend in the base and make a cut with a parting tool to define the length.
Blend in the base
Define the length
Finish
Sand to a good finish and add an oil. Once sanded you can part off from the waste wood.
Finish with a food safe oil
Parting off
Egg cup holder
To compliment your egg cup project why not make an additional egg cup holder. This attractive stand was a popular feature of traditional Victorian kitchens and keeps your egg cups in one handy place.
Cut the recess
Using a screw chuck, screw the blank onto the chuck and face it off then mark the diameter of the recess ready for cutting.
Face off the blank
Mark the diameter of the recess
Cut the recess in with a parting tool and remove the waste with a bowl gouge.
Cut the recess with a parting tool
Remove waste with a bowl gouge
Decorate and shape
Decorate the recess then gently scrape the base with a skew to flatten it.
Decorate the recess
Gently scrape the base with a skew
Once again using a bowl gouge, gently shape the outer edge of the base to give it some lift then tidy the outer edge with a bowl gouge.
Gently shape the outer edge of the base
Tidy the outer edge with a bowl gouge
Sand to a good finish then apply a food safe oil to finish the base.
Apply a food safe oil
Turn the base
Unscrew from the screw chuck and reverse onto the C Jaws. Using a drill chuck in the tailstock, drill a mortice ready for the handle.
Reverse onto the C Jaws
Drill a mortice ready for the handle
Remove the waste material with a bowl gouge. Once most waste has been removed, form the neck around the mortice.
Form the neck around the mortice
Flatten the top surface for the egg cups to sit on then flatten with a skew on its side as a scraper.
Flatten the top surface with a skew on its side
Sand and oil before beginning the handle.
Oil before beginning the handle
Turn handle
To make the handle, hold your blank between centres and rough down then clean to a good finish with a skew.
Rough down the handle blank
Clean to a good finish with a skew
Use a set of callipers to size the tenon to suit your base mortice. Next, start shaping the handle with your chosen design then sand and oil.
Size the tenon to suit your base mortice
Shape the handle with your chosen design
Sand the handle
Oil the handle
Tidy up any areas that may still have hold points in from the centres.
Tidy up any areas on the handle Tidy up any areas on the handle
Here's your finished egg cup holder.
Finished egg cup holder Finished egg cup holder
Made it? Share it!
Have you made our egg cup and egg cup holder projects? If so, we want to see them. Share you project pictures with us on social media. Search and tag @axminstertools on Facebook and Instagram. Or upload to our online gallery.
Leave a comment
