Pillar Drill | Why Pillars Drills Are A Good Investment
The woodworker’s precision powerhouse
What is a Pillar Drill?
A pillar drill—also known as a drill press—is a fixed drilling machine mounted on a column (or pillar) that allows for precise, repeatable drilling. Unlike handheld drills, pillar drills offer stability, accuracy, and control, making them ideal for woodworking tasks that demand consistency.
They come in two main formats:
- Bench Pillar Drills – Compact and ideal for smaller workshops or lighter-duty tasks.
- Floor Pillar Drills – Larger, more powerful machines suited to heavier workloads and taller workpieces.
Why woodworkers need a pillar drill
Drilling straight, clean holes by hand is notoriously tricky. Even with a steady hand and a sharp bit, slight deviations can ruin a joint or misalign hardware. A pillar drill eliminates this risk by holding the drill bit perfectly perpendicular to the workpiece, ensuring every hole is square and true.
For woodworkers, this means:
- Perfectly aligned dowel joints
- Accurate hinge and hardware placement
- Clean holes for plugs, pegs, or fixings
- Consistent depth control for repeat drilling
What you can do and what it replaces
Pillar drills are incredibly versatile. Here are just a few woodworking tasks where they shine:
- Joinery: Drill precise holes for dowels, biscuits, or dominoes.
- Cabinetry: Accurately position shelf pins or concealed hinges.
- Turning Prep: Bore centre holes in blanks before mounting on a lathe.
- Mortising: With the right attachments, cut square mortices for traditional joinery.
- Sanding: Fit a drum sander into the chuck to smooth concave curves or internal edges.
Before owning this machine, you might rely on:
- Cordless drills – Great for mobility, but hard to keep square.
- Drill stands or guides – Helpful, but not as stable or powerful.
- Jigs – Useful for specific tasks, but not as versatile.
A pillar drill replaces all of these with one robust, reliable machine.
Project inspiration
- Building a shaker-style cabinet with dowel joints
- Making a wine rack with evenly spaced holes
- Creating a pegboard or tool wall
- Drilling pilot holes for drawer runners
- Crafting wooden toys or puzzles with repeatable accuracy
Why it’s an investment
A pillar drill isn’t just a tool—it’s a workshop upgrade. Here’s why:
- Precision: Every hole is drilled at the exact angle and depth you set.
- Repeatability: Perfect for batch work or production-style projects.
- Power: Induction motors deliver smooth, consistent torque.
- Safety: Fixed drilling reduces the risk of slips or misalignment.
- Longevity: Built to last, many models come with a comprehensive guarantee
Accessories to enhance your setup
- Drill tables and fences for better workpiece support
- Vee blocks for drilling round stock
- Depth stops for consistent hole depth
- Dust extraction ports for cleaner working
Explore more in our Pillar Drill Accessories Guide.
Final thoughts
In summary, if precision matters in your projects—and let’s face it, when doesn’t it?—a pillar drill is a must-have. It’s a tool that grows with your skills, adapts to your needs, and delivers results that hand tools simply can’t match.
Ready to upgrade your workshop? Explore our full range of pillar drills and find the perfect fit for your space and style of work.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our blogs.
Get in touch!
Send us a photograph and tell us all about what you've recently purchased or what you've been making. Alternatively, get in touch via our social media platforms. Find us on Facebook or Instagram.
