Planer Thicknesser | Your Key To Perfectly Flat Timber
Planer Thicknesser – your key to perfectly flat timber
What is a planer thicknesser?
A planer thicknesser is a dual-function woodworking machine designed to:
- Plane the surface of a board to make it flat and true
- Thickness the board to a consistent depth across its entire length
It combines the capabilities of a surface planer (or jointer) and a thickness planer into one compact unit. The result? Boards that are not only smooth but also dimensionally accurate — ready for joinery, glue-ups, or finishing.
Shop by brand
Why woodworkers use planer thicknessers
Woodworkers rely on planer thicknessers for several key reasons:
- Time-saving efficiency: Quickly flatten and size timber without manual effort
- Precision: Achieve consistent thickness across multiple boards for uniformity in projects
- Versatility: Handle a wide range of wood types, from soft pine to dense hardwoods
- Cost-effectiveness: Mill rough-sawn timber yourself instead of buying pre-dressed wood
Whether you're prepping stock for a table top or squaring up reclaimed timber, a planer thicknesser ensures your materials are workshop-ready.
What you might use instead (and why it falls short)
While a planer thicknesser doesn't replace every tool, it can reduce reliance on:
- Hand planes – for flattening and thicknessing boards manually
- Belt sanders – often used to smooth uneven surfaces
- Table saws – for sizing boards, though not for flattening
- Jointers – if you have a combo machine, you won't need a separate jointer
It’s especially valuable for those working with rough timber or wanting to reclaim wood from pallets, old furniture, or offcuts.
What you can do with a planer thicknesser
This machine is ideal for:
- Furniture making – ensuring flat panels and square edges for joinery
- Cabinetry – preparing stock for doors, frames, and carcasses
- Wooden flooring – creating consistent planks for seamless installation
- Cutting boards – flattening and sizing hardwoods for food-safe finishes
- DIY builds – prepping timber for shelves, benches, and garden furniture
Its ability to produce professional-grade timber makes it a favourite among makers who value quality and consistency.
Final thoughts
If you're looking to take your woodworking to the next level, a planer thicknesser is a game-changing investment. It saves time, improves accuracy, and opens up a world of possibilities with raw timber. Whether you're working in a small shed or a full-scale workshop, this machine helps you start every project with perfect stock—and that's the foundation of great craftsmanship.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our blogs.
Get in touch!
Get in touch via our social media platforms. Find us on Facebook or Instagram.
Email updates
Not part of our Email Updates yet? Sign up for FREE to receive exclusive offers, new product launches and woodworking content tailored to your individual likes and interests.
