Resin Casting | Woodworking Activity
Resin casting requires a mould, which can be made from silicone, plastic, or other materials. The process begins with mixing the resin and hardener according to the manufacturer's instructions. Once the resin is mixed, you pour it into the mould and allow it to cure and harden.
There are various types of resin available, each with its own properties and applications. Epoxy resin is commonly used for its clarity and durability, while polyester resin is often used for larger castings. You can also add pigments, dyes, and other additives to the resin to achieve different colours and effects.
In summary, resin casting is a versatile and enjoyable activity that allows you to create unique and personalised items. With the right materials and techniques, you can produce high-quality castings that are both functional and decorative.
Here at Axminster Tools, we enhance your resin casting projects further by offering a range of products. These include:
- Moulds: Silicone moulds are highly recommended due to their flexibility which makes demoulding easier.
- Mixing Tools: Accurate digital scales for measuring resin components precisely.
- Stirring Sticks: Wooden or plastic sticks for thorough mixing without introducing bubbles.
- Heat Gun/Torch: Useful for removing air bubbles from freshly poured resin.
- Pigments & Dyes: Various colours available to customise your castings.
- Release Agents: To ensure easy removal of cured pieces from moulds.
- Safety Gear: Gloves (nitrile), safety glasses/goggles and respirators/masks for protection against fumes.
- Measuring Cups/Jugs: Graduated containers for accurate measurement of liquids.
- Sandpaper/Polishing Kits: For finishing touches on cured pieces ensuring smooth surfaces.
These tools will help ensure successful outcomes in your creative endeavours with resin casting.
Finally, here are some resin casting videos and blogs that might be useful:
Cast a Resin and Burr Sphere | How To: This blog provides a step-by-step guide and video tutorial on casting a stunning resin and burr sphere using EcoPoxy resin and Lizard Blanks moulds. It covers everything from preparation to turning your blank on a lathe.
Resin Mixing & Pouring | Tips & Techniques: This article explores useful tips and techniques for mixing and pouring resin, helping you get started with resin in your woodworking projects.
Woodworking Wisdom Videos: This section features a variety of videos, including demos, projects, and top tips from woodworking experts. You can find the latest videos and upcoming streams on their YouTube channel.
In summary, resin casting is a versatile and enjoyable woodworking activity that allows you to create unique and personalised items. By mixing resin with hardeners and pouring it into moulds, you can produce high-quality castings that are both functional and decorative. This technique is perfect for embedding objects, filling voids, or creating intricate designs. Resin casting can elevate your woodworking projects to new artistic heights, ensuring each piece is not only functional but also a work of art.
