Woodworking Wisdom
Sanders Maintenance | Keep Your Finishing Results Smooth
Drum sander abrasive
Why maintenance matters
Sanders work in demanding conditions - handling constant vibration, fine dust and variable pressure. All of which can take a toll over time. Finishing tools, meanwhile, rely on cleanliness and precision to produce clean, consistent results.
Regular maintenance:
  • Improves sanding and finishing quality
  • Extends tool life
  • Reduces downtime and repairs
  • Helps maintain effective dust extraction
  • Keeps tools safer and more comfortable to use
General Sander Maintenance
Keep them clean
Dust is the biggest enemy of sanding tools.
  • After each use, blow out air vents and housings using compressed air or a soft brush
  • Wipe down the exterior to prevent dust build-up around switches and speed controls
  • Pay particular attention to dust ports and extraction channels, keeping them clear to maintain airflow
Avoid using solvents or excessive moisture - a dry brush and gentle air flow are usually enough.
Inspect before and after use
Make visual checks part of your routine:
  • Look for damaged cords or plugs
  • Check backing pads and platens for cracks, warping or excessive wear
  • Ensure sanding pads are securely attached and running true
Catching small issues early can prevent larger failures later.
Sander Maintenance Tips
Below is the full set of category-specific maintenance guidance to help you prolong the life of your sanders and finishing tools.
Sanding Discs, Belts and Sheets
Use the right abrasive
Using worn or incorrect abrasives makes the tool work harder and produces poorer results.
  • Replace discs, belts or sheets as soon as they lose cutting efficiency
  • Match grit type and size to the material and task
  • Avoid mixing incompatible brands or hole patterns that restrict dust extraction
Store abrasives correctly
Poor storage can ruin abrasives before they even reach the sander.
  • Store flat where possible to avoid curling
  • Keep belts loosely coiled rather than sharply folded
  • Store in a dry environment to prevent moisture damage
Abrasive storage
Backing Pads
Backing pads are wear items and should be checked frequently.
  • Replace pads that show cracking, melted areas or loss of hook-and-loop grip
  • Remove built-up resin or dust from pads using a rubber cleaning block or stiff brush
  • Ensure replacement pads are matched to the machine’s specification
A worn pad can cause uneven sanding, vibration and premature motor wear.
Bearings, Vibration and Moving Parts
Excess vibration often signals wear.
  • If a sander becomes noticeably noisier or rougher, stop and inspect
  • Bearing wear may require professional servicing, especially on random orbit and belt sanders
  • Never continue using a sander with unusual noises — it’s likely to cause further damage
Dust Extraction and Collection
Efficient dust control protects both the tool and the user.
  • Empty dust bags or boxes regularly
  • Clean or replace filters according to manufacturer guidance
  • Inspect hoses for blockages, splits or loose connections
  • Ensure seals and ports are intact for effective airflow
Poor dust extraction not only affects results, but can lead to overheating and premature component failure.
Bobbin sander extraction
Drum sander extraction
Palm sander extraction
Maintenance for Finishing Equipment
Finishing tools demand cleanliness for consistent results.
Polishers and buffers
  • Clean pads thoroughly after each use to remove compound build-up
  • Allow pads to dry fully before storage
  • Inspect backing plates for wear or damage
  • Store pads separately to avoid contamination with dust or grit
Replacing pads when worn ensures even polishing and prevents surface damage.
Spray Equipment (where applicable)
If you use spray systems for finishing:
  • Clean thoroughly immediately after use
  • Flush lines, nozzles and cups with the appropriate cleaning solution
  • Inspect seals, needles and tips for wear
  • Store clean and dry to prevent blockages or corrosion
Clean equipment produces cleaner finishes - and avoids costly rework.
Fuji cleaning kit
Storage and Transport
How tools are stored matters as much as how they’re used.
  • Store sanders in cases or cupboards to keep dust off sensitive components
  • Avoid leaving tools resting on sanding pads
  • Keep tools dry and away from temperature extremes
  • Coil cables loosely to prevent internal wire damage
Good storage habits significantly extend tool life.
Final thoughts...
Sanders and finishing tools reward good care with consistent performance and high-quality results. By keeping them clean, using the right abrasives, maintaining dust extraction and storing them properly, you’ll extend the life of your tools and enjoy smoother, more reliable results every time. A few minutes of maintenance at the end of each job can save hours - and expense - further down the line.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our blogs?
Get in touch!
Get in touch via our social media platforms. Find us on Facebook or Instagram.
Leave a comment
