Rob Stoakley takes you step by step through the process of fitting a brass router bush to a router, listing all the tools and accessories you will ...
Latest posts
Rob Stoakley takes you through producing a shape that will fit exactly into a corresponding cut-out, using different combinations of router bushes ...
MethodStep 1Prepare the materials ready for veneering: substrate, veneer leaves, glue and roller.Step 2Place thick paper on the baseboard inside th...
A transfer jig is an easy and extremely accurate way of marking out the pins on a dovetail joint.
The circular saw can be notoriously inaccurate when used freehand. When combined with an accurate crosscut 'T' square, cuts at exactly 90° are easy...
Replace shop bought grow bags and make your own permanent wooden grow box. Greenhouse planters are very easy to make using a few simple hand tools.
