Cutting and joining commercial veneers needn't be a difficult process. Learn how to join veneers in order to make a larger surface.
Latest posts
Making your own deckchair is a great DIY project. Here are instructions for a standard sized adult deckchair.
At home, in the workshop or on site, driving any sort of screw is a fundamental way of joining materials together. Done correctly, using the right ...
There isn’t much call these days in the normal run of events to use an old fashioned, steel, countersunk screw, let alone brass screws, so much so ...
Octagonal Handle MethodStep 1Machine the blank 25mm square, mark the centres at each end.
Important!
This must be done accurately or the flats on t...
Types of fileTang - designed to be inserted into a handle for the file
Heel - also known as the shoulder, connects the tang to the file
Teeth - the...
