Tite-Fix® Screws
When it comes to woodworking, decking, or joinery, the right screw can make all the difference. Whether you’re fitting hinges, laying flooring or building a decking, Tite-Fix® offers a solution that combines precision, durability and ease of use through a range of different screw types.
Why is Tite-Fix® different?
Unlike generic screws, Tite-Fix® has developed a range of screws that are meticulously designed for specific tasks, to allow you to achieve the best possible results.
Task-specific: Each screw in the Tite-Fix® range is crafted with the end-user in mind. Whether you’re working on a delicate woodworking project, or a robust construction job, there’s a Tite-Fix® screw tailored to meet your needs perfectly.
High performance features: Tite-Fix® screws are not just ordinary fasteners. They boast advanced features like their triangular core and twin start threadform, which ensures a fast, secure hold that lasts the life of the installation. For the outdoor range, Net-Coat® corrosion resistance provides durability that stands the test of time.
Trusted by Professionals: Reliability and quality are the hallmarks of Tite-Fix® screws. They are trade tested and trusted by both professionals and DIY enthusiasts, making them to go-to choice for anyone seeking excellent, quality results.
Let’s delve into each range:
Screw-Tite®:
Perfect for multi use applications The flagship of the Tite-Fix® range, Screw-Tite® is a multi-purpose screw that incorporates both single and twin threads on the same screw. The twin thread tip allows for an immediate start, and a fast, balanced drive, whilst the single course thread drives the screw easily and leaves a firm fixed screw in place.
The Tri-lock™ thread consists of three flats on the surface of the screw, which rapidly expands the material, resulting in a fast insertion and clamped finish. It reduces insertion torque by 25%, minimising timber damage and securing a strong hold. It’s suitable for hardwood, softwood, masonry and more.
Hinge-Tite®:
Use for hinges and latches Specifically designed for hinges and latches, Hinge-Tite® features a plain angled head that sits flush within the hinge. With their triangular core, the screws eliminate the need for pilot holes in most applications and feature the TS thread form for a fast installation. Available in brass or chrome finishes, these screws are hardened to prevent snapping during insertion.
Deck-Tite®:
Ideal for decking, sheds and timber structures Deck-Tite® screws are perfect for decking, fencing, and sheds. Their Net-Coat® protection resists galvanic corrosion from pressure-treated timbers and combats the elements. With a single thread start and spiral point, they penetrate timber easily without causing damage, ensuring a flush fix without splitting the wood and without the need to pilot. Deck-Tite® is DeckMark Plus accredited.
Deck-Tite Plus, made from 316 stainless steel, offers superior corrosion resistance for marine grade applications or in polluted environments.
Timber-Tite®:
Excellent for landscaping and structural timber applications Timber-Tite® screws are ideal for heavy-duty landscaping and structural timber applications, providing a flush fix without splitting the timber. Suitable for both indoor and outdoor use, they allow for fascia board fixing with minimal damage. Hardened for high tensile strength, they feature Tri-Lock™ thread for a tight, locked fix and a coarse single thread for fast insertion. The Net-Coat® green finish resists corrosion, often eliminating the need for a pilot hole. Timber-Tite® is DeckMark Plus accredited.
Lost-Tite®:
Best for skirting boards, architrave, panelling, tongue and groove cladding & flooring Lost-Tite® screws offer a semi-concealed, flush fix, perfect for tongue and groove cladding and flooring, skirting boards and more. Their reduced head provides an almost hidden fixing. The twin start allows for rapid insertion whilst the coarse, single thread clamps tight. A secondary under head thread prevents extrusion even if timbers shrink. This design eliminates the need for glues, nails, or panel pins.
Tongue-Tite®:
Suitable for when you want hidden fixtures on tongue and groove cladding & flooring The original solution for laying tongue and groove flooring, Tongue-Tite® screws feature a single coarse thread that eliminates the ream-out effect, providing high pull-out retention and preventing squeaky boards, whilst a twin tip ensures a fast start. The narrow-countersunk head allows the next board to sit in place neatly. They can be removed without damage, just in case the boards need to come up in the future.
Floor-Tite®:
Great for wooden or chipboard flooring Floor-Tite® screws are perfect for wooden or chipboard flooring. With Tri-lock™ and TS threadform, they ensure a fast start and pull the board down tightly to prevent squeaky floorboards. You can easily recognise their blue, passivated zinc finish. They are easy to remove if needed and won't damage the board.
Whether you’re working on a decking project, fitting hinges, or securing your floor, the Tite-Fix® range of screws is a reliable and secure fixing to turn to.
