Woodworking Wisdom
How To Woodturn A Lazy Susan
Lazy Susan
Woodturning your Lazy Susan
Step 1
Select two separate wood blanks a suitable size to your chosen size of Lazy Susan bearings, roughly 20mm bigger than the bearing. The top section will need to be bigger than the base section.
Lazy susan bearings and two wood blanks
Step 2
Starting with the Lazy Susan base section, screw in a faceplate to one side of the smaller wood blank and attach to the lathe.
Step 3
Rough out and turn the base to your desired size.
Rough out wood blank on the lathe
Turn a recess in the wood blank
Step 4
Turn a recess into the base to accommodate the C jaws, roughly 3/4mm. This will be the foot of the Lazy Susan.
Step 5
Sand the base using abrasive grits 100/150/240/400, in this order.
Sand the wood base
Apply finishing oil to the base
Step 6
Apply toy safe finishing oil.
Step 7
Remove from the lathe turn the base around, fitting the recess into the expanding C jaws.
Base turned over and attached to chuck with C jaws
woodturning
Step 8
Rough out and face up the upper side of the base.
Step 9
Measure the size of the Lazy Susan bearing, using dividers mark out from the middle of the wood and turn a recess 230mm diameter - 6mm deep to fit the bearing.
How_To_Turn_A_Lazy_Susan12
Step 10
Shape the outside edge of the base, tidying up any edges and create a beaded cove.
Step 11
Sand working through abrasive grits 100/150/240/400, in this order.
Step 12
Step 13
Remove from the lathe and set aside the base.
Ensuring bearing fits into recess
Attached faceplate to wood blank for platter top
Step 14
Screw a faceplate into what will be the Lazy Susan platter top, turning the underside of the top first.
Step 15
Rough out and turn the underside of the platter.
Turning a flat into the underside of the platter top for the bearing to fit
Turned underside of the platter top with recess for the bearing to fit
Step 16
Then measure and mark out to make a flat bigger than the base - 240mm.
Checking bearing fits correctly into turned recesses
Step 17
Turn a round recess collar; 140mm as a solid disc for the base to sit on but not so deep that the timber meets. Double check the top bearing fits in with the base section.
Step 18
Shape the sides with a radius.
Turning a recess to accommodate C Jaws
Step 19
Mark out and turn a recess to accommodate the C jaws. Making sure not to take too much thickness away from the whole piece and compromise the top.
Step 20
Sand working through abrasive grits 100/150/240/400, in this order; you will only need to sand to the outer rim as you will not be able to see further once put together.
Sanding the underside of the platter top
Final sanded platter underside
Step 21
Step 22
Remove from the lathe, turn over and attach the recess to the C jaws. Remove the faceplate from the upper side.
Face off the surface of the platter top, adding a rim to the platter shape.
Step 23
Face off and clean up the surface of the lazy Susan platter top, add in a rim to the platter shape.
Step 24
Shape a flat face and get rid of the screw holes from the faceplate.
Step 25
Smooth out and check the platter is level with a ruler or straightedge.
Step 26
Sand working through abrasive grits 100/150/240/400.
Sanding down the upper side of the platter top
Final sanded upper side of the platter
Step 27
Apply toy safe finishing oil and buff.
Lazy Susan bearing assembly
Step 1
Place the Lazy Susan bearing on the bottom section of the platter, position the bearing where access aligns with a fixing hole. Drill one hole all the way through the base - this will be used as the access hole when attaching the top.
Bearing is placed on the base of the platter. Drill one hole all the way through the base
Step 2
Using small screws and the access hole, screw the bearing into the base section.
How_To_Turn_A_Lazy_Susan27
Bearing is screwed into the platter base
Using the access hoe, top platter is screwed into the bearing
Step 3
Place the base onto the underside of the platter, using the access hole screw the bearing into the platter, rotate and screw the next hole until all 4 are secured.
Lazy Susan
Leave a comment
