Bosch T101BR Jigsaw Blades Reverse Cutting For Wood
- 40mm thick hard and soft wood, plywood and chipboard
- Reversed down cutting teeth
- Available in packs of 5 or 25
Hard and soft wood, plywood and chipboard up to 40mm. Reversed down cutting teeth for splinter-free cutting in veneered or coated boards.
Blade Type | HCS, Ground and Taper Ground |
Jigsaw Blade Length | 74 mm |
Jigsaw Blade Type | Reverse Cutting |
Max Cutting Depth | 40 mm |
Model | T101BR |
Tooth Pitch \ tpi | 2.54 mm \ 10 tpi |
