The GRS-16 Connector allows seamless integration of the GRS-16 Guide Rail Square with the TSO Parallel Guide System Gen 2. Designed for a secure fit, it offsets the square slightly for improved visibility and accurate alignment. Compatible with GRS-16 models featuring 100 mm accessory holes (standard since 2017), this connector makes setup fast, precise, and hassle-free.
With the launch of the Parallel Guide System Gen 2, the tracks have been redesigned to be universal—removing left/right orientation for quicker, simpler setup. The change means the GRS-16 Guide Rail Square can no longer attach directly to the tracks. This connector provides the secure, purpose-built link needed to join the GRS-16 to Gen 2 Parallel Guide Tracks.
Supplied with: 1 qty. Guide Rail Square Connector for Parallel Guide System Gen 2
Mounting hardware
