Strength, speed and versatility
Combining portability, quick setup and robust strength, the Perform Quick Bench lets you tackle jobs at home, in the workshop or on site with ease. Use it to support benchtop machines or as a reliable DIY table for tasks like decorating—an adaptable, all-round solution that’s effortless to transport and simple to assemble.
GIF showing the quick and easy assembly of the Perform quick bench
Quick assembly
The simple, hassle-free design ensures the bench can be set up in a matter of seconds.
A man operating a yellow Perform wood planer on a Perform quick bench in a workshop, feeding a piece of wood through the machine.
Stable and stronge
When a top is fitted to the bench, it’s extremely stable and has a load capacity of up to 1,000kg; ideal as a portable workbench for DIY jobs and holding machines.
A person holding a long black PERFORM branded carrying bag with two top handles, shown against a light grey brick wall with tools hanging on the right.
Portable and compact
The Perform Quick Bench offers a generous size when assembled yet folds down into a compact, light form for storing. This makes it easy to transport and convenient to store in small spaces.
A GIF showing the Perform quick bench in various applications
Perfect for...
Suitable for a range of different tasks, it is perfect used as a machine stand, worktable, car boot table or even for decorating tasks such as wallpapering.
Discover more easy work-holding solutions
The Perform Quick Clamp makes clamping simple and secure. Its sturdy tripod base provides excellent stability indoors or out, while a clamping force of up to 1,000kg keeps even large or heavy materials firmly in place. Perfect for projects that need a steady hold wherever you’re working.
Find out more
The Perform Quick Bench is a compact, portable work table that sets up in seconds and delivers serious stability. Ready to use, straight out of the box, you can simply add a stable top to the stand to make it into a table. With a load capacity of up to 1,000kg, it's perfect as a machine stand or workbench, and even for use as a car boot or camping table.
When you're finished, it folds away fast - compact enough to store easily in your home, car or workshop.
Folded size: 130 x 195 x 930 mm
Open size: 670 x 1270 x 730 mm
Nett Weight 4.1kg
Overall Length 1,200 mm
EAN Barcode 5052511143269
