Quietly powerful. Brilliantly efficient.
Designed for performance, the AP145CE Cyclone Extractor combines a two-stage cyclone system, multiple extraction ports, remote control, a powerful motor and more, making it a must-have for high demand workshops.
Buy with confidence
Cyclone extraction diagram
From dust to chips
Two-stage cyclone systems are highly efficient. The cyclone separates larger particles and chips from finer dust, removing approximately 99% of waste from the airstream, significantly reducing filter clogging and maintaining strong suction performance over time.
High air flow capacity - AP145CE
High airflow capacity
The 1,080 m3/hr @ 100mm and 1,380m3/hr @ 150mm airflow capacity delivers powerful extraction, perfect for handling demanding dust loads in busy workshops. It ensures cleaner air and improved tool efficiency.
Remote control - AP145CE
Time delay switch with remote control
The remote control lets you switch the machine on or off from anywhere in the workshop, saving time and improving convenience. The time delay switch keeps the extractor running for 2, 4, 6 or 8 hours after the machine stops, ensuring a cleaner workspace by clearing lingering dust.
Quiet operation
The quiet, yet powerful 1.5kW motor creates a comfortable working environment, reducing noise levels, making it suitable for shared or indoor workshop spaces.
Wheeled waste bin - AP145CE
Wheeled waste bin
The wheeled waste bin has a 118 litre container volume, allowing waste disposable to be easier and cleaner, as the frequency of emptying is reduced.
Dual paddle cleaning - AP145CE
Cartridge filter with manual dual paddle cleaning
The cartridge filter captures fine dust particles down to 1 micron, helping to protect respiratory health and to maintain air quality. The paddle is operated by a crank handle, so you can easily change the filter to help extend the life of your filter.
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Axminster Professional AP145CE Cyclone Extractor is perfect for small professional workshops. Before the airflow passes through the extractor's fan, the cyclone separates the larger waste particles from the finer dust, meaning the fan operates more efficiently compared to other types of extractor. Only a small amount of fine dust will reach the cartridge filter, therefore less mess is created, so less cleaning is required.
The cyclone, body, filter, and collection bag are all supported by a durable tubular steel frame. Power comes from a 1.5kW induction motor, delivering strong suction and reliable performance. A cartridge filter with a manual cleaning system ensures consistent efficiency, while the 118 litre main waste bin, mounted on wheels, allows for easy removal and mobility around the workshop. Fine dust is collected separately in a bag beneath the filter cartridge, which requires emptying only occasionally. For versatility, the unit offers a choice of either three 100mm inlets or a single 150mm inlet.
Airflow: as measured in the Axminster workshop 1,080m³/hr @100mm and 1,380m³/hr @150mm.
The cyclone extractor is supplied with a remote control so you can switch on or off from anywhere in the workshop.
Please note: the hose size should not be reduced to less than 75mm, otherwise a marked drop in performance will occur.
Please note, if you require an EU plug, please ensure you purchase 113776
Airflow 1,080 m³/hr @ 100 mm (30-37 m/s) 1,380 m³/hr @ 150 mm (18-21 m/s)
Filter Performance 99% 1 micron
Inlet 1 x 150 mm or 3 x 100 mm
Overall L x W x H 1,045 x 660 x 1,745 mm
Power 1.5 kW
Rating Frequent Use
Sound Power Level LwA [Uncertainty K] 84 dB(A) [3.0 dB]
Plug Fitted UK 3 pin plug
Model AP145CE
Container Volume 118 litre
Filter Surface Area 2.6 m²
Nett Weight 89 kg
Static Pressure 2,000 Pa
Voltage 230 V
EAN Barcode 5052511142262
  • UK Mainland - £70
