Easy Wood Tools
Easy Wood Tools Mid-Size EASY DETAILER™
SKU: 109261
£119.18
£99.32 Excl. VAT
  • Versatile go‑to detailing tool for bowls, platters, boxes and spindles
  • Detailer for small coves, beads and fine decorative details
  • No sharpening required – simply rotate the carbide cutter to a fresh edge
  • Solid carbide cutter keeps an edge many times longer than HSS
  • Suitable for turning dry or green wood, acrylics, and resin
  • 9.5mm sq section bar sits flat and steady on the tool rest for easy control
  • 350mm American maple handle, copper ferrule for strength and leverage
The Easy Wood Tools Mid‑Size Easy Detailer™ is a carbide woodturning tool designed for creating small coves, beads, and fine decorative details when turning bowls, platters, boxes, spindles, and other projects.
With increased reach compared to the Easy Start range, it is a versatile go‑to detailing tool for turners working on larger workpieces while still requiring precise, controlled cuts.
Featuring a replaceable diamond‑shaped carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑Size Easy Detailer™ delivers excellent stability and easy control with no sharpening required.
The longer handle provides improved leverage and balance, making it well suited to bowl and faceplate work, while remaining intuitive and predictable for turners progressing beyond smaller tools.
Designed for controlled, accurate cutting, the Mid‑Size Easy Detailer™ allows you to create fine details cleanly and consistently, even on larger blanks.
The square section bar ensures the tool remains flat and steady on the tool rest, and when used parallel to the floor at centre height, the risk of catches and snatches is virtually eliminated, supporting confident detail work at the lathe.
With no sharpening needed, maintenance is simple - when the edge becomes dull, just loosen the fixing screw and rotate the cutter to a fresh edge.
Easy Wood Tools’ long‑lasting carbide cutters keep an edge many times longer than HSS and are suitable for turning dry or green wood, as well as acrylics.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
What you get
Diamond‑shaped carbide cutter fitted as standard
Hex key for easy cutter rotation or replacement
350mm long American maple handle with copper ferrule for added strength
Colour‑coded handle for easy identification within the Easy Wood Tools range
Specifications
Overall length: 533mm
Bar profile: 9.5mm square section
Optional upgrade
Negative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin materials, while also producing a finer, smoother finish on timber as skills develop.
Replacement Tip Ci4 (109262)
EAN Barcode 5052511133406
