Easy Wood Tools
Easy Wood Tools Mini EASY DETAILER™
SKU: 109318
€110,00
  • Use for small bowls, goblets, bottle stoppers, pens etc
  • Detailer for small coves, beads, and other fine details
  • No need to sharpen; simply rotate cutter to a fresh edge
  • Solid carbide tip keeps an edge many, many times longer than HSS
  • Use to turn dry or green wood, acrylics and resin
  • 9.5mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
The Easy Wood Tools Mini Easy Detailer™ is a carbide woodturning tool designed for creating fine details, small coves, beads, and precise decorative features on small to medium projects, including bowls, spindles, and general craft work. As part of the Mini range, it provides the control needed for detailed work while offering more stability than Micro tools.
Fitted with a diamond‑shaped replaceable carbide cutter, the Mini Easy Detailer™ allows you to create crisp, defined details with minimal effort.
Its compact yet more substantial build improves control compared to Micro tools, while the flat‑profile bar sits securely on the tool rest, making it easy to use without needing to master complex tool angles or sharpening techniques.
The Mini Easy Detailer™ delivers clean, accurate detailing cuts, making it ideal for adding definition and decorative elements to your work. It excels at shaping beads, cutting coves, and refining intricate features on smaller or moderately sized pieces.
When used parallel to the floor at centre height, the tool remains stable on the rest, helping to reduce catches and allowing for smooth, controlled detailing as you refine your work to a finished result.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Tool type: Mini carbide detailing tool
Cutter type: Diamond‑shaped carbide cutter
Range: Mini (compact tools with added stability over Micro)
Bar profile: Flat section for stability on the tool rest
Handle: Hardwood with copper ferrule
Negative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to achieve a smoother finish and greater control on more delicate or brittle materials.
Replacement Tip Ci4 (109262)
EAN Barcode 5052511133451
