Designed for the Perform Replaceable Tip Turning Tool Set, this 12mm TCT round blade is perfect for creating curves and contours. Simply screw it onto your turning tool. Made from durable tungsten carbide, it stays sharper longer than traditional turning tools, offering extended tool life and consistent performance.
When the edge dulls, simply rotate to a fresh cutting edge. Once all four edges are used, replace the tip - no sharpening required.
Supplied in a 2 pack.
