Perform
Perform TCT Square Blade (Pkt 2)
SKU: 113577
€8,95
  • Fits Perform Replaceable Tip Turning Tool Set
  • Ideal for roughing and square stock removal
  • 11mm square blade
  • Tungsten carbide stays sharp longer
  • Rotate tip for fresh edge - no sharpening
  • Supplied as a convenient 2 pack
Designed for the Perform Replaceable Tip Turning Tool Set, this 11mm TCT square blade is ideal for roughing out material and removing square stock. Simply screw it onto your turning tool. Made from durable tungsten carbide, it stays sharper longer than traditional turning tools, offering extended tool life and consistent performance.
When the edge dulls, simply rotate to a fresh cutting edge. Once all four edges are used, replace the tip - no sharpening required.
Supplied as a 2 pack.
EAN Barcode 5052511143139
