Spare Parts
  • Axminster KJD12 NVR Switch 230V 1ph c/w Box Axminster KJD12 NVR Switch 230V 1ph c/w Box
  • KEDU Safety Interlock Switch
  • Axminster NVR Switch 230V 1ph E Stop Axminster NVR Switch 230V 1ph E Stop
  • Arbortech Drive Belt
  • Axminster Drive Belt for M900/M950
  • KEDU KJD20-2 Switch 230V 1ph KEDU KJD20-2 Switch 230V 1ph
  • KEDU KJD12 Switch 230V 1ph KEDU KJD12 Switch 230V 1ph
  • KJD16 Rocker Switch 230V 1ph KJD16 Rocker Switch 230V 1ph
  • KEDU KJD17 NVR Switch 230V 1ph KEDU KJD17 NVR Switch 230V 1ph
  • Axminster Drive Belt for CT150 Planer
  • Axminster KJD18-9 NVR Switch 230V 1ph Axminster KJD18-9 NVR Switch 230V 1ph
  • Axminster DKLD DZ-6-2 Switch 230V 1ph Axminster DKLD DZ-6-2 Switch 230V 1ph
  • Axminster KJD17B NVR Switch 230V 1ph Axminster KJD17B NVR Switch 230V 1ph
  • Drive Belt For AC370WL, AWVSL1000, CCBL Lathes
  • Motor Run Capacitor 50 MFD 450V 50 x 92 mm
  • Motor Run Capacitor 8 MFD 450V 35 x 56 mm
  • Motor Run Capacitor 35 MFD 450V 43 x 95 mm
  • Motor Run Capacitor 40 MFD 450V 45 x 95 mm
  • Motor Run Capacitor 12 MFD 450V 35 x 72 mm
  • Motor Run Capacitor 6 MFD 450V 35 x 45 mm
Axminster Spare Parts
Keep your woodworking machinery running smoothly with our range of Axminster spare parts and replacement components. Whether you're carrying out routine maintenance, replacing a worn part or repairing a machine, finding the right spare can help extend the life of your equipment and get your workshop back up and running. Our selection of Axminster machinery spare parts includes drive belts, switches, motor capacitors, pulleys and other essential components for bandsaws, lathes, sanders, planer thicknessers and more. Find the replacement parts you need to keep your machinery performing reliably. Be sure to check your machine's model number and the part specifications before ordering to ensure compatibility.
