Ambersil Corrosion Inhibitor Spray
952144
From £17.38 £14.48
  5. Half Star
4 Reviews
  • Buy 3 for £15.64 £13.03 each
  • Buy 6 for £14.77 £12.31 each
  • Buy 15 for £13.90 £11.58 each
Low Stock - Ready to dispatch
  • Use on ferrous metals in humid conditions
  • Will not stain or mark components
  • Suitable for use on board boats
  • Can be used as anti-seize/anti-rust treatment for fasteners
  • Film will not harden or crack and allows for handling
Suitable for protecting ferrous metals in humid conditions, this clear coating will give long lasting protection against rust and corrosion on metal components in both external and internal environments. Just spray lightly onto unprotected metal and it forms a continuous homogenous film that will not stain or mark components. The film will resist acid from the skin and so allows for subsequent handling. If you need to remove it, white spirit applied with a cloth will suffice. As it will also remove surface moisture on application it is suitable as an anti-seize coating on bolts, hinges, fixings or any moving part. Having been testing for over 250 hours in salt spray tests, it is great for use on a boat.
4.50 4
