Arbortech Industrial Woodcarver
- Fits most 100mm and 115mm angle grinders
- Replaceable and rotatable teeth do away with sharpening
- Pro-Guard acts as depth stop, safety guard, parallel guide and chip deflector
- Tackles the hardest timbers, rapid wood removal
- Use for rough shaping, trenching or straight cuts
- Cutting is done on the periphery of the blade
Arbortech Teeth for Industrial Woodcarver BladeFrom £44.48 £37.07
The ultimate powered woodcarver; the Arbortech cutting disc with tungsten tips will tackle the hardest of timbers, included reclaimed timber with included dirt and other debris. This unique tool, made to fit most 100mm or 115mm angle grinders, is precision machined from high quality steel and fitted with three tungsten carbide teeth. The cutting teeth are rotatable and replaceable so there's no need for sharpening. Replacement teeth are available, but with a life of almost 25 times longer than the Pro 4 it may be some time before they are required. From a purely economic standpoint the Industrial Arbortech is a sound investment. Its extreme long life, replaceable teeth and ability to cut a wide variety of materials make it excellent value for money. The Industrial Kit, includes the blade, key and Pro-Guard. The Pro-Guard is a multi-purpose device which acts as a depth stop, a safety guard, a parallel guide and a chip deflector all in one.
EAN Barcode | 9313478190205 |
