Axcaliber 2 Wing Slotting Cutters
- Excellent for freehand or router table use
- Available sizes are 2, 3, 4, 5 & 6mm
- 8mm bore
A range of Axcaliber quality 2 wing slotting cutters suitable for machining grooves for plywood etc. Available sizes are 2, 3, 4, 5 and 6mm all with an 8mm bore. Cutter diameter of 47.6mm with 22mm bearing gives a 12.7mm groove depth. For biscuit joints use 4mm slot cutter 666277. N.B.Suitable arbors are available in 1/4"(6.35mm) and 1/2"(12.7mm) shank sizes.
D = Overall Diameter | 47.5 mm (1.7/8") |
