Axcaliber Adjustable Chamfering Cutter Head
501069
- For jointing or chamfering at various angles
- Can also rebate with optional scribing disc
- 40mm TC knives held in swivelling bodies
- Infinitely adjustable or use 7.5° and 15 positive stops
- 120mm diameter body, made in high tensile alloy
Show more
Show less
This block is for chamfering at various angles. Suitable for jointing and, by using an optional scribing disc (501071), suitable for rebating wooden boards and solid timber. The TC knives are reversible and are mounted in swivelling bodies, infinitely adjustable +/-45°, or you can use the 7.5° and 15 positive stops. An angle scale is fitted. The block is 120mm in diameter, the TC knives are 40mm deep. Made in high tensile alloy for lightness and strength.
Bore Size | 30 mm |
EAN Barcode | 5052511106028 |
