Axcaliber Bevel Trim Cutter
- For flush trimming laminates
- Bearing guided for consistent result
- Ideal for use in palm routers or laminate trimmers
- Precision made on multi axis CNC machines
- PTFE coating helps cutter to remain free of resin
- 1/4" shank
For flush trimming laminates where a bevel is required this bearing guided cutter will give consistently good performance. A good choice for use in palm routers or laminate trimmers.
D = Overall Diameter | 23 mm |
EAN Barcode | 5052511029648 |
K = Cutter Angle | 30° |
X = Depth of Cut | 9.5 mm (3/8") |
