Axcaliber Contract 300mm TCT Saw Blades
- Generously sized tips brazed onto tensioned quality steel plates
- Rip Cut (28 teeth)
- General Purpose (40 teeth)
- Crosscut (72 teeth)
- 3.1mm kerf, 30mm bore, reducing bushes available
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find a blade to suit every requirement. Bore size 30mm. A range of bore reducing bushes are available. A great panel saw blade.
Blade Diameter | 300 mm |
Bore Size | 30 mm |
Hook Angle | 5° |
Kerf | 3.1 mm |
Maximum RPM | 6,500 rpm |
Plate Thickness | 2.2 mm |
