Axcaliber CutPro 165mm Thin Kerf TCT Saw Blades
From £24.18 £20.15
  5. Half Star
6 Reviews
  • Thin kerf, 33% narrower compared with similar standard blades
  • Ideal blades for cordless circular saws
  • Uses less energy resulting in longer battery runtimes
  • Alternate top bevel for outstanding finish and performance
  • Micro-grained TCT tips for a sharper, longer lasting edge
  • Tensioned, pre-stressed, quality steel plates guarantee true running
  • 1.5mm kerf, 20mm bore
To produce your best work you need to cut with the best blades
Axcaliber CutPro Circular Saw Blades use the latest production techniques and the finest materials. Cut at a more controlled pace for a neater cut using your mitre saw and experience longer runtimes and less strain on your cordless plunge or handheld circular saws.
Designed for a first class result in all natural timbers and man-made boards, these blades are the perfect choice for professional use.
They are particularly suitable for cordless circular saws. The thin 1.5mm kerf is 33% less than similar standard blades. They require less energy from your battery for a given cut resulting in longer runtimes and less strain on your machine. The alternate top bevel (ATB) grind gives you rapid progress through the cut and a quality finish. Axcaliber Cutpro circular saw blades use the latest production techniques and the finest materials. The blades feature micro-grained TCT tips. The laser-cut plates substantially reduce noise while cutting. A faint tensioning ring halfway across the plate indicates where each individual blade undergoes a pre-stressing to guarantee smooth running.
The bore size is 20mm.
4.70 6
