Axcaliber Cutter for Axcaliber Dovetail Jigs (19-30mm Material)
951241
From £16.48 £13.73
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Buy 3 for £15.65 £13.04 each
  • Buy 6 for £14.83 £12.36 each
  • Buy 10 for £14.00 £11.67 each
In Stock - Ready to dispatch
  • Greater cutting depth than standard cutters
  • Suitable for a material thickness of approx 19-30mm
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps cutter to remain free of resin
  • 1/4" shank
Assurance with Axcaliber
- see how they're made
With a greater cutting depth this cutter is offered as an alternative to the standard cutter supplied with the Axcaliber and Axminster dovetail jigs and is suitable for a material thickness of approx 19-30mm.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
