Axcaliber Dovetail Cutters
AX801216
AX801216
- Create strong good-looking joints
- Use for cabinet and drawer joints
- Generally used with dovetail jigs
- Cut dovetails, mitred and sliding dovetails
- Precision made on multi axis CNC machines
- PTFE coating helps cutter to remain free of resin
- 1/4" shank
Axcaliber A5 Foam Router Cutter PresenterSpecial Price £4.30 £3.58 was £13.58 £11.32 Save £9.28 £7.73
Show more
Show less
Precision dovetail cutters offering differing diameters, depths of cut and angles suitable for many applications requiring tight reliable joints.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
