Axcaliber Edge Breaker Router Cutter Set 4
- Exact and controlled rounding over
- Perfect arris removal
- Set of 4: 1, 1.5, 2 and 2.5mm radii
- Bearing guided for straight or curved edges
- Minute relief prevents corners digging in
- Essential prior to applying paint or varnish
- All 1/4" shank
Axcaliber Round Nose Cutter - D=25.4 - X=19 - R=12.7mm - S=1/2"From £22.98 £19.15
Woodworkers traditionally round over a corner or create a slight chamfer on an edge, ‘removing the arris’ as it is known. There are several reasons for this. A sharp corner is uncomfortable to handle. Depending on the species, the wood may splinter or crumble. A sharp corner will not take the finish. You cannot paint a sharp edge. Try putting a coat of light paint over dark wood, once dry a dark unpainted line on the edge is obvious.
The Edge Breaker set rounds over sharp edges for a very exact and controlled result. There are 4 radii: 1mm, 1.5mm, 2mm and 2.5mm, all bearing guided for rounding straight or curved edges. Importantly, the radius of each cutter rather ending with a 90° corner has a slight relief angle to ensure a perfect finish. Even a 1mm radius makes a world of difference, whatever finish you apply.
All cutters are 1/4" shank.
EAN Barcode | 5052511116355 |
