Axcaliber FineLine Gent's Saw 15tpi - 250mm
- For small jointing tasks, picture frames, beading etc.
- 15tpi fine toothed blade
- Comfort grip handle
This FineLine precision Gent's saw is made to the same exacting standard as the rest of the range. The 45mm deep blade will tackle small jointing jobs as well as being ideal for cutting picture frames, beads, etc with ease. It’s a good saw to use in a small mitre box. The blade is fitted securely into a comfort grip handle, the length is 250mm with fine 15tpi induction hardened teeth.
Blade Thickness | 0.50 mm |
EAN Barcode | 5052511007233 |
Kerf | 0.75 mm |
Length of Blade | 250 mm |
Overall Length | 250 mm |
Tooth Pitch \ tpi | 1.70 mm \ 15 tpi |
