Axcaliber Flush Trim Cutter with Down Shear - Bottom Bearing
951296
From £35.58 £29.65
32 Reviews
  • Buy 3 for £33.80 £28.17 each
  • Buy 6 for £32.03 £26.69 each
  • Buy 10 for £30.24 £25.20 each
  • For flush trimming or following a template
  • Cutting edges, angles give a downward shearing action
  • Produces a very clean cut with minimum breakout
  • Fitted with bottom bearing
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps cutter to remain free of resin
  • 1/2" shank
Assurance with Axcaliber
- see how they're made
An excellent choice for flush trimming or following a template, these cutters have the cutting edges placed at an angle to give a downward shearing action. This results in a very clean cut with minimum breakout. Bottom bearing cutter with 1/2"(12.7mm) shank, 19mm diameter and 50mm depth of cut.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
4.80 32
