An excellent choice for flush trimming or following a template, this cutter has the cutting edges placed at an angle to give a downward shearing action. This results in a very clean cut with minimum breakout. Top bearing cutter with 1/2"(12.7mm) shank, 19mm diameter and 50mm depth of cut.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
