Axcaliber Hinge Recessing Router Cutters
666087
666087
- Perfect for cutting hinge mortices or similar applications
- Easy to use with palm routers
- Follow with a corners chisel to ensure a perfect fit
- Precision made on multi axis CNC machines
- PTFE coating helps minimise resin build-up
- Diameter 12.7mm
- Depth of cut 19mm
- 1/4" shank
Show more
Show less
These 1/4"(6.35mm) shank cutters are great for use in a small palm router when recessing hinge mortices or similar applications. Just follow up with one of our corner chisels for chopping out the radius in the corners to ensure the perfect fit.
D = Overall Diameter | 12.7 mm (1/2") |
EAN Barcode | 5052511029600 |
X = Depth of Cut | 19 mm |
