Axcaliber Rebate Set 1/2" (7 Bearings)
506273
From £61.28 £51.07
9 Reviews
  • Buy 3 for £58.22 £48.52 each
  • Buy 6 for £55.15 £45.96 each
  • Buy 10 for £52.09 £43.41 each
In Stock - Ready to dispatch
  • 7 interchangeable bearings for a host of rebate sizes
  • Shear cut for best finish
  • Cutter diameter 35mm, depth of cut 19mm
  • Largest bearing allows flush cutting
  • SAE4140 steel shank hardened to Rockwell 45 HRC
  • Diamond ground micrograin tungsten carbide tip
  • Virtual mirror finish ensures durable, clean cutter
  • PTFE coating helps minimise resin build-up
  • 1/2" shank
Assurance with Axcaliber
- see how they're made
A versatile rebate set available in a 1/2" (12.7mm) shank size, which includes seven different bearing sizes offering the following depths of rebate: 12.7mm, 11.1mm, 9.5mm, 8mm, 6.35mm and 3.2mm and flush cut using the largest bearing. The a depth of cut is up to 19mm. This bottom bearing rebate set allows you to make an endless number of cuts by adjusting the cutting height on the router and changing the bearing on the bit. It can be used to produce rebates; small tenons even in curved work and the carbide tips are set at an angle to give a clean shearing cut.
4.20 9
