Axcaliber Stile and Rail Cutter (Shaker)
951288
From £59.18 £49.32
  5. Half Star
19 Reviews
  • Buy 3 for £56.22 £46.85 each
  • Buy 6 for £53.27 £44.39 each
  • Buy 10 for £50.30 £41.92 each
In Stock - Ready to dispatch
  • A simple and attractive Shaker style profile
  • One cutter used for both parts of the joint
  • SAE4140 steel shank hardened to Rockwell 45 HRC
  • Diamond ground micrograin tungsten carbide tips
  • Excellent for making your own kitchen unit doors
  • 1/2" shank
  • This cutter is for use in router tables only
Assurance with Axcaliber
- see how they're made
This Axcaliber stile and rail cutter offers an attractive Shaker style profile with the advantage of having just one cutter for the moulding and scribing cuts. You simply alter the height of the cutter in the router table to switch from one operation to the other. The timber should be positioned face down on the table surface for the moulding cuts and face up for the scribing cuts. Excellent for making your own kitchen unit doors. N.B. Recommended timber thickness 18 - 22mm. Please note this cutter is for use in router tables only.
4.60 19
