Axcaliber Tongue & Groove Set
952564
952564
- Axcaliber Tongue and Groove Set (1/2" shank)
- A fast efficient method of producing this classic joint
- 12.8 x 6.35mm tongue in material up to 19mm thick
- PTFE coating helps minimise resin build-up
- 1/2" shank
- This cutter set is for use in router tables only
Show more
Show less
Designed for router table use, this matching pair of cutters are excellent for quickly producing a tongue and groove joint in material up to 19mm thick. Each cutter is 47.6mm in diameter with a 22mm bearing which produces a tongue or groove 12.8mm long by 6.35mm wide. (1/2" shank only).
C = Width of Groove | 6.35 mm (1/4") |
D = Overall Diameter | 47.5 mm (1.7/8") |
EAN Barcode | 5052511054077 |
H = Horizontal Depth of Cut | 12.7 mm (1/2") |
Shank Diameter | 1/2" (12.7 mm) |
