Axminster Woodturning Deluxe Assembly/Disassembly Pen Press
106069
From £124.98 £104.15
  5. Half Star
110 Reviews
In Stock - Ready to dispatch
  • Combined tool for assembly and disassembly of pens
  • Offers reliability, accuracy and control
  • Press pen parts together for perfect results
  • Allows disassembly of virtually any pen
  • Features a strong arm with ergonomic handle
Making pens has never been easier
The Axminster Woodturning Deluxe Assembly/Disassembly Pen Press is the perfect choice for when it comes to assembling or disassembling your pens.
Accurate results
This all-in-one tool allows you to not only assemble your pens with accuracy and ease, but also to disassemble virtually any pen, making it a must have tool for any pen turner. The deluxe pen press helps you to produce perfectly pressed pens, with accurate results every time by simply clamping in place and using the handle to push together your finished pen parts.
Versatility
The press can accommodate larger pens, up to 20mm in diameter. And also use to assemble longer projects, by simply removing the pen support mechanism.
All in one place!
There is even a handy storage box to help keep all your loose pen parts in one place when assembling or disassembling your projects.
The Axminster Woodturning Deluxe Assembly/Disassembly Pen Press lets you assemble and disassemble pens all on one easy-to-use combined tool. It acts as a traditional pen press offering reliability, accuracy and control to press your pen parts together. The disassembly function gives you an invaluable way to take virtually any pen apart. The Pen Press takes large pens up to 19mm in diameter and a maximum length of 225mm. It features a strong arm with an ergonomic handle, a parts storage tray to prevent small parts going awry during assembly, a punch bar and placement rack, lock handle set, scale and end support.
4.70 110
