Axminster Workshop Drum Sander Kit
- 25 piece kit, use in a pillar drill or hand drill
- Consists of 5 rubber drums of different diameters
- Replacement sleeves are available separately
Axminster Workshop Drum Sander Sleeve Set - MediumSpecial Price £1.39 £1.16 was £1.98 £1.65 Save £0.59 £0.49
Axminster Workshop Drum Sander Sleeve Set - CoarseSpecial Price £1.39 £1.16 was £1.98 £1.65 Save £0.59 £0.49
A 25 piece kit consisting of five rubber drums: 12.7mm dia x 12.7mm long, 19mm dia x 25mm long, 25 mm dia x 25mm long, 38mm dia x 38mm long, 50mm dia x 38mm long and supplied with fixed diameter sanding sleeves in 80 and 120 grit. Endless uses and a real must for anyone's tool kit. Max speed 1500rpm. Supplied in a plastic case.
Abrasive Grit | Mixed |
EAN Barcode | 5052511020874 |
