Axminster Engineer Series Machine Coolant Pump System
104941
From £229.98 £191.65
In Stock
  • Suitable for mills, drills, lathes and metal cutting bandsaws
  • Compact design for convenient positioning in small space
  • Flexible delivery hose with shut-off valve to control flow rate
  • 9 litre coolant tank with internal baffle to control sediment
  • Swarf sieve in coolant return to collect waste
  • 95W 230V motor provides up to 24 l/min flow
  • Fitted with in-line switch, cable and plug
The Axminster Machine Coolant System consists of a 9 litre tank and a 95W 230V electric pump. Supplied as a complete kit, it also includes a flexible discharge hose and nozzle, 2m delivery hose pipe, 1m return hose, shut off valve and mounting bracket and fixings.
The unit is easy to retrofit to an existing machine. It is relatively small, so should not present any problems finding a convenient location. It will fit inside a lathe cabinet, under the bench, wherever you like, bear in mind you will need to top it up and clean it out occasionally.
The Axminster Machine Coolant Pump System is suitable for use with drilling/milling machines, small lathes, metal cutting bandsaws, etc. The waste sieve filters swarf and is easy to remove and clean. The tank has a mid baffle, which prevents sediment reaching the pump unit.
Supplied with an inline switch, cable and fitted with 13A BS plug. 390mm long, 270mm deep and 320mm high.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
5.00 5
