Axminster Professional AP940DDS Drum Sander - 415V
107639
From £6,299.98 £5,249.98
2 Reviews
In Stock
  • Enquire - contact us for a personalised quote
  • Powerful and robust for high production sanding
  • 5.5kW(415V) main motor with separate conveyor motor
  • Digital read-out scale allows accurate settings
  • Machine supplied with two abrasive loadings (80 and 100 grit)
The AT940DDS twin drum finishing sander is intended for large professional workshops. Power is supplied by a 5.5kW(415V, 3ph) for the sanding drums and a 190W for the conveyor belt drive.
The 150mm diameter drums are precision machined from aluminium castings. The abrasive is wound spirally around the drums and securely held by wedge clamps. Coarser abrasive on the front and finer on the rear. There is a very accurate setting system for the rear roller, allowing easy adjustment to accommodate the different grades of abrasive. Three pressure rollers maintain contact between the work and the conveyor belt. This ensures that the work is held in close contact with the belt, giving safe operation and a uniform thickness to the finished work.
A full width stop bar on the front of the machine can be reached from almost any position, enabling the machine to be stopped quickly.
The AP940DDS will handle thicknesses between 1mm and 133mm, adjustment is via a handwheel. A digital read-out scale allows accurate settings. Twin 100mm dust ports provide efficient dust extraction. This solid and dependable machine that can easily handle high volume throughput of a professional workshop.
Machine supplied with two abrasive loadings (80 grit and 100 grit).
N.B. Drum sanders are intended to be used with already planed and thicknessed material. Overall a planer/thicknesser is meant to dimension timber, the drum sander to finish it.
N.B. 16A supply is required, (Fitted with red 16A plug 415V 3 pin, E + N). Please ensure that your workshop electricity supply is adequate. If unsure, seek advice from a qualified electrician.
Machine Classification
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
5.00 2
