Axminster Woodturning Soft Sanding Pad
From £4.98 £4.15
32 Reviews
  • Arbor mounted foam pads
  • 1/4" shanks
  • Available in 50mm(2") and 75mm(3") diameters
  • Hook and loop mounted discs available in full range of grits
These arbor mounted foam pads have 1/4" shanks and are available in 50mm (2") and 75mm (3") diameters. The hook and loop mounted discs, which are available in a full range of grits, have many applications and are particularly suited to sanding and finishing turned bowls. The foam conforms to the curve and the contra rotations of the lathe and drill mounted pad eliminate swirl marks to produce a fine finish.
4.20 32
