Axminster Professional Alloy Bar Clamp/Spreader
From £18.68 £15.57
  5. Half Star
127 Reviews
  • Spring-loaded jaw face ensures even pressure distribution
  • Ideal for using on slightly tapered surfaces
  • Reversible fixed jaw to convert the clamp into a spreader
  • Robust aluminium alloy construction; throat depth of 80mm
Key features:
Axminster Professional Clamp/Spreader
See the entire range
The jaws are robust aluminium alloy on a 20 mm x 6 mm steel bar. These die-cast jaws are capable of applying substantial pressure to the workpiece. Squeezing the handle advances the moving jaw. The spring-loaded face is slightly angled so its top touches first as the jaws close. As pressure is applied, the spring compresses to ensure even pressure distribution, even on slightly tapered surfaces. The fixed jaw is reversible to convert the clamp quickly into a spreader. The jaw faces have non-marring, glue-resistant pads and the clutch operates with a simple release. All sizes – 160Kg max clamping pressure.
Lifetime Guarantee.
Warranty Axminster Professional Clamps Lifetime Guarantee
4.70 127
